Im using the RMX controller and VJD 5.2.2 I get a scratch sound when I move the Jog Wheel forward but its silent when I pull it back....What am I doing wrong???
Posted Thu 22 Jul 10 @ 11:34 am
Sounds like you got the smart scratch turned on.
Huey
Huey
Posted Thu 22 Jul 10 @ 12:10 pm
Where and how do i turn that off???
Posted Thu 22 Jul 10 @ 12:37 pm
Posted Thu 22 Jul 10 @ 12:45 pm
there's 3 buttons at top of the mixer on the default skin go to scratch panel and the option is at the bottom of the panel, a little keylock just disable it
Posted Thu 22 Jul 10 @ 1:08 pm
I dont have a "config" option on the version that i have......Only using the version that came with my hardware
Posted Thu 22 Jul 10 @ 1:41 pm
maybe with a picture
Posted Thu 22 Jul 10 @ 2:21 pm
I appriceiate the pic.....however I dont have that version......My program looks nothing like that.....I have VDJ 5.2.2......What version do u have???
Posted Thu 22 Jul 10 @ 2:55 pm
just checked and sorry i didn't know this version was so limited. :/
please look at the wiki https://virtualdj.com/wiki/RegistryValues.html and check the value in window registry
the value to search in the registry are "smartscratch" must be "0" to disable the feature
Posted Thu 22 Jul 10 @ 3:33 pm
can you setup shortcuts in your version?
Posted Thu 22 Jul 10 @ 7:48 pm
