hi everybody,
i need your help with a strange problem that suddenly poped up .when im playing atrack in the wright deck and then starting to make loops using the pioneer cdj 400
it wont sync with the track in the left deck
when im loopin using the keybord or directly from the software deck however ,it works fine.to solve this problem i did the following steps
1-i tested each 400 as a single controller
the loops in left deck syncronized well with the track in the wright deck on both players,but wont sync when i loop the wright deck with left deck
2-i uninsulled the 400 driver and reinstalled it again
3-i uninstalled the vdj version i was using and installed the latest version
4-i deleted the xml both in c-vdj
and in d
5-i configured the mapper
6-i changed the usb cables
none of the actions helped me to solve the problems.
if anybody here knows how to solve it
it would be great.thanks.
and in d
Posted Wed 21 Jul 10 @ 6:40 am
Kindly check if you have the smart_loop activated of both decks.
Posted Thu 22 Jul 10 @ 1:35 am
thanks alot,how could i be so blind!it works fine now.i confiegred it of course and it use to work fine.i didnt notice that i pressed the button by mistake.its imberessing ,what more can i say.
Posted Thu 22 Jul 10 @ 6:24 am
