Whenever i select my sooundcard (dj-io or m-audio fast track) Cue crashes. If I have the m-audio connected before loading cue, it crashes. If I have no sound card connected to the usb, it works fine. The dj-io lets me load the program, but when i select it in the audio preferences it crashes cue.
If anyone can help me it would be greatly appreciated.
Posted Sat 17 Jul 10 @ 8:53 pm
Windows XP?
Please post the crashguard report.
Posted Sun 18 Jul 10 @ 1:10 am
its W7
where do I find the report?
Posted Sun 18 Jul 10 @ 1:37 pm
TLOSS error
SING error
DOMAIN error
R6029
- This application cannot run using the active version of the Microsoft .NET Runtime
Please contact the application's support team for more information.
R6028
- unable to initialize heap
R6027
- not enough space for lowio initialization
R6026
- not enough space for stdio initialization
R6025
- pure virtual function call
R6024
- not enough space for _onexit/atexit table
R6019
- unable to open console device
R6018
- unexpected heap error
R6017
- unexpected multithread lock error
R6016
- not enough space for thread data
This application has requested the Runtime to terminate it in an unusual way.
R6009
- not enough space for environment
R6008
- not enough space for arguments
R6002
- floating point not loaded
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: ... <program name unknown> ÿÿÿÿu@ y@ ÿÿÿÿ¹@ ½@ GetProcessWindowStation GetUserObjectInformationA GetLastActivePopup GetActiveWindow MessageBoxA user32.dll ÿÿÿÿx%@ |%@ Program: A buffer overrun has been detected which has corrupted the program's
internal state. The program cannot safely continue execution and must
now be terminated.
Buffer overrun detected! A security error of unknown cause has been detected which has
corrupted the program's internal state. The program cannot safely
continue execution and must now be terminated.
Unknown security failure detected! ÿÿÿÿ?>@ C>@ ( ( ( ( ( H „ „ „ „ „ „ „ „ „ „ ‚ ‚ ‚ ‚ ‚ ‚ h ( ( ( ( H „ „ „ „ „ „ „ „ „ „ ‚‚‚‚‚‚ H ÿÿÿÿHB@ LB@ ÿÿÿÿE@@ I@@ ÿÿÿÿA@ A@ ÿÿÿÿäC@ èC@ ÿÿÿÿ•I@ ™I@ H pr@ P]@ 9 ¤] 4_ P „^ t_ àP ”^ ¢^ ´^ È^ Þ^ ð^ þ^ _ _ ’b €b nb \b €_ ”_ ¦_ ¸_ È_ Ö_ è_ ü_ ` ` .` J` d` |` –` ¬` Æ` Ø` æ` ô` a a a ,a 6a Ba Na Za ja xa „a ša ªa ¶a Ða àa öa b &b 6b Lb ¤b R_ B_ `_ . CloseHandle ` CreateProcessA OTerminateProcess ƒWaitForSingleObject cUnmapViewOfFile zOpenProcess ^MapViewOfFile iGetLastError N CreateFileMappingA KERNEL32.dll ;SendMessageA ã FindWindowA ÍWaitForInputIdle USER32.dll wGetModuleHandleA ¯GetStartupInfoA GetCommandLineA ßGetVersionExA ¯ ExitProcess ˜GetProcAddress :GetCurrentProcess ”WriteFile ±GetStdHandle uGetModuleFileNameA `UnhandledExceptionFilter í FreeEnvironmentStringsA MGetEnvironmentStrings î FreeEnvironmentStringsW ‡WideCharToMultiByte OGetEnvironmentStringsW SetHandleCount ^GetFileType
HeapDestroy HeapCreate vVirtualFree HeapFree HLoadLibraryA õ GetACP ‹GetOEMCP ü GetCPInfo HeapAlloc sVirtualAlloc HeapReAlloc ÊRtlUnwind InterlockedExchange {VirtualQuery HeapSize —QueryPerformanceCounter ÕGetTickCount >GetCurrentThreadId ;GetCurrentProcessId ÀGetSystemTimeAsFileTime :LCMapStringA kMultiByteToWideChar ;LCMapStringW ²GetStringTypeA µGetStringTypeW lGetLocaleInfoA yVirtualProtect »GetSystemInfo ¡=@ q!@ ¨)@ * x2 ù@ ÐT@ ¤T@ xT@
àS@ ´S@ „S@ `S@ 4S@ üR@ ÔR@ œR@ dR@ <R@ ˜Q@ x „Q@ y tQ@ z dQ@ ü `Q@ ÿ PQ@ À À – À À Ž À À À ‘ À ’ À “ À
Œ ÿÿÿÿ€
Næ@» ¤ `‚y‚! ¦ß ¡¥ Ÿàü @~€ü ¨ Á£Ú£ þ @þ µ Á£Ú£ þ Aþ ¶ Ï¢ä¢ å¢è¢[ þ @~¡þ Q QÚ^Ú _ÚjÚ2 ÓØÞàù 1~þ “ °X@ ²Z@ .
Posted Sun 18 Jul 10 @ 1:47 pm
this log is from the cracked version i have, but I tried by dloading the trial from the forum and it dosent work. The program works without the sound card connected just fine. theres a conflicct with my internal and external sound card. im using an m-audio fast track pro or a dj-io
it happens with both. i can use traktor and ableton but Cue dosent work
Posted Sat 24 Jul 10 @ 3:27 pm
ok i did process of elimination and came to the conclusion that the ASIO driver is crashing Cue. It works fine with everything else, but when i switch the driver too headphones and asio, it crashes as soon as I press ok. If i leave it with the internal card it works fine.
Im using ASIO4all with the djio or fast-track pro.
please somebody heeeeellp me!!!!
Im using aa Gateway NV54
x64
AMD Turion II 2.4Ghz
x64
Posted Sat 24 Jul 10 @ 10:43 pm
