I have a simple slideshow of 140 jpegs numbered 1-140... all in a folder. I 'open' the folder, 'select' '1', and it starts.
The screen displays jpeg 1, 10, 100, 101-109, 11, 110-119, 12, 120.............
I'm on a timeline so this is weird. What can I do??
Posted Fri 16 Jul 10 @ 11:18 pm
well computers see numbers with a tenths place. number them 01,02,03,04,05,06,07,08,09,10, 11,12 and so on.
Posted Sat 17 Jul 10 @ 7:07 am
Try to de renaming with 'Total Commander' - http://www.ghisler.com.
With his multiple renaming tool you can do numbering from 1-999 or whatever. Also you can rename with space between the numbers like 0,5,10,15 ...
Take a look here: https://virtualdj.com/homepage/jakovski/blogs/3459/MP3-Tagging_-_the_easy_way__eng_.html
Greets, Heiko
Greets, Heiko
Posted Sat 17 Jul 10 @ 7:10 am
