Hard to explain the problem and its kinda intermittent as well. "Sometimes" when I've been playing for a while and attempt to load up my next MP4 file for play.. the files loads and looks correct and I can see my 1st cue point BUT.. the cue point is kinda in the wrong place. Actually what looks like is the beginning of the file is actually is NOT. It can be like a few bars into the actual file. My workaround for this is to reload the same file. Often the 2nd load will load correctly but there are times when I actually have to load the file 3-4 times for it to load from the BEGINNING of the track. This NEVER happens at the start of the night.. Usually I've been playing for 15-30 minutes at least.
I'm running 6.1 on Win7 and using the ASIO option with the CDJ-2000s. The only thing that's diff in my setup is the 2000s. Is it possible these are causing the problem?
I hope this makes sense. Has anyone else had this problem at all? Any suggestions how to fix?
Thanks
-Mike
Thanks
-Mike
Posted Fri 16 Jul 10 @ 7:37 am
