Please can someone help? I cant seem to use the jog wheel to grab the first beat of the tune i want to play.
I keep having to try and hit pasue at the precise second the beat comes in and make a cue point.
Are there any settings i can change so the jog wheel can be used to grab the beat so i can let the beat go when i want to mix the tune?
Thanks for any help
Thanks for any help
Posted Tue 06 Jul 10 @ 9:54 am
No, this is not possible on the RMX because it does not have touch sensitive jogwheels.
You will need to cue the song up on the beat and set a cue point there, as you would do on a normal DJ CD player that is not touch sensitive.
Posted Tue 06 Jul 10 @ 5:04 pm
Cheers mate. I was afraid that would be the case
Posted Wed 07 Jul 10 @ 3:37 am
