hi
i jus installed the virtual dj 6.1 full version
my probem / or question is :
when we are playin Live with virtual dj ..... we have a master sound and a headphone sound
so
in config i set the OUTPUTS to Headphones and then master left chan / headphone right chan
ok ...
then my problem is how can i make the song play in master or in my ear in headphones !??? when playin live @ party for example.
so
ok ...
Posted Tue 06 Jul 10 @ 2:41 am
Both headphone sockets on the M1530 are connected to the same source - they are not independant outputs. This means you use one socket, and the left channel on that socket is the master, and the right socket is the headphones.
This is far from ideal for several reasons, you are far better off using a professional soundcard that is actually up to the job rather than bodging it.
Posted Tue 06 Jul 10 @ 4:21 am
so it gonna solve if i buy a usb portable sound card?
and if it is .... in virtual dj where can i select that a song play in headphone or in master?
Posted Tue 06 Jul 10 @ 4:34 am
You need a 4 channel (ie 2 stereo) output card to work properly.
It's not either or; if you're using the internal software mixer then levels to the master output are controlled by the volume faders and crossfader (just like a DJ mixer) while the headphones are controlled by the currently selected deck for PFL (again just like a DJ mixer).
Posted Tue 06 Jul 10 @ 9:37 am
