Hello,
I am new to VDJ and was wondering how to use my mic properly. I am able to use it to talk when I switch tracks, but I can't seem to turn it off unless I turn it off with my inline switch. Is there a way to toggle the mic on/off?....Can I map a key on my keyboard to do the same or even press and hold that key?
Thank You in advance,
Hayden
Hayden
Posted Tue 29 Jun 10 @ 2:15 am
Mic switching isn't handled by VDJ. You need to do it with your mixer, or some controller/soundcards have a mic on/off switch on them (e.g. the Hercules RMX).
Posted Tue 29 Jun 10 @ 6:05 am
If you are using a standard Windows microphone, then you can find instructions on how to map a button to do this on the following page:
https://virtualdj.com/wiki/VDJScript%20Examples.html
Posted Tue 29 Jun 10 @ 7:00 pm
