Just bought a Hercules RMX to do a birthday party and i downloaded the latest driver (2010_HDJS_2) for Windows Vista and my computer says its ready to use but when i try to open virtual dj, it says "controller not detected"....am i missing a step???
Posted Thu 24 Jun 10 @ 12:21 pm
HELP!! I just installed Virtual DJ and I'm using the Hercules RMX and when I'm playing a song it stops until I touch either a fader or button and then it comes back on. Whats up???
Posted Thu 24 Jun 10 @ 9:00 pm
Have you guys tried going to the CONFIG tab in the top right. Then trying the "Sound Setup" tab to select your soundcard.
That should do it.
I disconnect and connect my RMX (I only use it for gigs) all the time.
That should do it.
Posted Fri 25 Jun 10 @ 3:11 am
Be sure to also download and install the latest verison of VDJ LE (5.2.2), available in the DOWNLOAD section of this site (you seril number will be required)
@ djchris73
The LE version included with the Rmx is preconfigured to work directly and exclusively with Rmx soundcard, so the Sound Setup menu is not available.
@ djchris73
Posted Fri 25 Jun 10 @ 8:24 am
I did that and its still saying controller not detected
Posted Sat 26 Jun 10 @ 2:16 am
