I am looking for a good pair of Studio Monitors that will be under $500 CAD. I have looked around and have been hearing that "M-Audio BX8A Studio Monitors" are the way to go. I am only into Electronic music (house, trance, etc.). If you have experience with this stuff and can give me your advise/input I would really appreciate it.
Also, I am getting into producing my own music and this is namely the reason why I want to get a set of monitors.
Cheers!
Cheers!
Posted Mon 21 Jun 10 @ 12:17 pm
hey dude :)
studio monitors is something you have to hear for yourself...
nobody can help you with that,however...
i bought myself 2 krk rp8 3 weeks ago,and i tried krk,m audio monitors(the ones you suggest)and the yamaha 50 serie...
the m audio's sounded a bit to flat for me(especially the bass)
but the sound whas quite clear...
but i went for the krk's nonetheless...
my suggestion,go to the store and try different monitors,and buy what you like :)
don't forget to take some cd's with you !!
lesley
lesley
Posted Mon 21 Jun 10 @ 4:48 pm
I have some BX8s and I love them. I've had them for years, in a small studio setting they rock.
Posted Mon 21 Jun 10 @ 5:11 pm
