Not sure if it's possible or the question has been asked already , but is it possible that the cue monitoring plus the master (Pgm) can be heard on Channel B (Cue) in a setup like (a midi controller like a hercules mk2 and an audio dj 4 where I use channel B for cue monitoring and channel A for Master). Really want to kno because I'm planning on moving on from Timecode vinyls and mixer which has cue/master to fully midi and audio interface only.
Posted Mon 21 Jun 10 @ 12:12 am
Anyone able to answer cueing and listening to the master mix on the same channel? Please I really neeed to know.
Posted Mon 21 Jun 10 @ 8:38 am
Try mapping the "headphone_mix" VDJScript action to a knob on your controller. The description is "change the mix of the PFL (0% is only the cued deck, 100% is the master output)."
Is this what you want?
Posted Mon 21 Jun 10 @ 12:07 pm
Bradleys I think thats exactly what I mean. Thank you Thank you Thank you Thank you. Support still hasn't answered but you did. Thats exactly what I wanted.
Posted Mon 21 Jun 10 @ 1:12 pm
HELP!!!
I am using a Vestax VCI-100, with VDJ Pro, & an iMIC ext card. I cant seem to be able to monitor the tracks in the headphones! I can either have a monitor, or a main out, but not both. What am I doing wrong??
HELP!!!!
HELP!!!!
Posted Tue 05 Oct 10 @ 10:34 pm
