guys doing a family party saturday and want to know the easiest way to do a slideshow of family photos.
can i load it in clipbank and best way to make a slideshow.thanks in advance.
know this sounds amatuer questions but never did it before.have family comming from different countries so want to show off a bit lol
vdj is my hero lol
vdj is my hero lol
Posted Tue 08 Jun 10 @ 12:46 pm
I think if you make a folder with only the pics you want displayed, select "slide show" in video effects, choose that folder then activate "slide show".
Posted Tue 08 Jun 10 @ 1:23 pm
Download and use the SBDJ Slideshow. his plugin has some improvements over the original slideshow.. (like automatically resizing pictures, etc etc)
Posted Tue 08 Jun 10 @ 1:32 pm
get in touch with me on skype mate, you know you want too.... lol, we'll sort some extra bits out for ya.
Posted Tue 08 Jun 10 @ 1:45 pm
thanks guys quality answers as usual..will do both now and try it out later.
just looked at dowload section and only sbdj slideshow is for version 5.is this the lates one
Its the latest one (he has another one in the works , but its not finished yet I dont think)
It DOES work with VDJ 6, I have 6.08 on mine, and I just used it last week.. zero problems!
Posted Tue 08 Jun 10 @ 3:03 pm
brill thanks mate ill give it a go
Posted Tue 08 Jun 10 @ 3:14 pm
I usually put them in a separate folder & run them as a slide show, works great.
Posted Tue 08 Jun 10 @ 10:57 pm
i will have more than 12 pics mate.also the sbdj slideshow do you just click on the folder or have to load them one by one
Posted Thu 10 Jun 10 @ 2:29 pm
Select a folder and go :)
Posted Thu 10 Jun 10 @ 6:05 pm
