Okay: turn down your gain just a bit so the circle fits in the red box. :)
Also: turn down the "Silence" knob down a little bit and try if the problem still exists.
Posted Fri 11 Jun 10 @ 8:33 am
Nah, didnt fix it:\
Posted Sat 12 Jun 10 @ 7:18 pm
Okay, enable clearsound and try again, if it doesn't help, enable LP noise filter and try again. If still not working: set the lead time slider to zero and try again.
Posted Sun 13 Jun 10 @ 7:50 am
it doesnt change anything...
Posted Wed 16 Jun 10 @ 7:40 am
Your timecode settings are entirely correct. Must be something different.
Posted Fri 18 Jun 10 @ 5:59 am
guess what, I just set up the exact same set up and got the same results, cdj100's and maya, the cue doesnt work . I build clubs for a full time living and am not new to this. I tryed it with the dennon and the cdj 1000 had no issues. I got the configuration to work and play then it would stop and I had to reload the stupid time code in the configure and then click on the 10000 then have to revert back to the virtual dj setting and it works for a while. I dont get it and if it will not work for the stampeed im out about 15 000$ so its time to go to something more trusted, if anyone finds a issues post it asap.
Posted Wed 07 Jul 10 @ 9:06 pm
here is the weird thing my time code is square? whats with that? The cue doesnt work as the person above stated. I have tried all the time codes then when I changed the combination to be with computer 2 with delta 66 sound card everything works fine. So then from process of trial and error I realized that the dennon needs to be with the maya and the cdj100 with the delta 66 and then everything works , its a huge pain but it happens to be the only way to make everything work.
Posted Wed 07 Jul 10 @ 9:14 pm
p.s your not going crazy..
Posted Wed 07 Jul 10 @ 9:15 pm
As I sent you in your ticket - the input level is to high.
With the Maya, the Maya Config panel the Input level should be somewhere around 30%-40% any higher and you will start to get weird things happening with timecodes. CD decks are way strong outputs than TT, that is why the Input Level on the Maya needs to be so low.
Posted Wed 07 Jul 10 @ 9:30 pm
ok , if this is true then why When I changed the soundcards did it work like a top, I this that the issue lies in the drivers for maya 44 maybe its the asio settings, All I want is for this to work and the cue button to do its actuall job. I will try and repost the effect after. P,s your answer on midi assignement is wicked it is all assigned including clipbank now they need to be able to make clip play flash videos. then im gold. you rock thanks
Posted Thu 08 Jul 10 @ 12:11 am
so . the error code was 0007e and I removed maya and all the drivers and then dropped the volume as you said and boom, its good to go. even the cue works. thanks and much respect to everyone.
Posted Thu 08 Jul 10 @ 1:11 am
