Go to your download center and update to the newest version and then try it.
Let use know what it does, in more detail other then "it doesn't work"
Huey
Huey
Posted Fri 24 Jun 11 @ 2:36 pm
Hello! Guys, I've been reading through every forum here. I've done it all. I can't even load a track onto the decks. My laptop recognizes the mixdeck, but VDJ 7.0.2 doesn't read my mixdeck. Please someone help.
Posted Thu 29 Dec 11 @ 9:32 pm
Do you have the Mixdeck in MIDI mode??
Posted Thu 29 Dec 11 @ 9:35 pm
Yes. Midi mode, CH1 and CH2 on PC and Cue Master on Ch1/Ch2. and nothing. I can't even map.
Posted Fri 30 Dec 11 @ 3:08 pm
Can you upload a pic of your settings??
Posted Fri 30 Dec 11 @ 3:46 pm
Please see:
https://virtualdj.com/wiki/MixDeck.html
Posted Fri 30 Dec 11 @ 6:10 pm
hi guys, i have just bought a mixtrack pro, which is a hardware controller, i thought it could do what i wanted but it appears not, anyway I wanted to record my radio shows, mic and hardware, however I cant record onto my software, it says there is a problem with the soundcard. I was hopin someone could help me please
Posted Sat 31 Dec 11 @ 6:46 am
Please open your own new topic rather than hi-jacking an existing one that is not related to your question in any way.
The topic is about the Numark MixDeck, which is a different controller to the MixTrack Pro.
To open a new topic, please click on the pen and paper icon at the top of the forum topic list page.
Also, please use the hardware technical support forums for questions like this: https://virtualdj.com/forums/31/Hardware_Technical_Support.html
Posted Sat 31 Dec 11 @ 12:12 pm
default mapping... the eject button is set to swap the deck on virtual DJ so u might want to check that also. make sure on your LCD that you see 1 on deck one and 2 on deck two. if that's correct then the sound card configuration needs to be checked
Posted Sat 31 Dec 11 @ 6:37 pm
Hi
I have a numark mixdeck and having problems when trying to play music from my VDJ as the mixdeck switches sides and the faders dont work.
I am struggling to find someone who can help on a Saturday
Posted Sat 03 Mar 12 @ 10:40 am
Please see:
https://virtualdj.com/wiki/Decks%20inverted%20on%20MIDI%20controller.html
https://virtualdj.com/wiki/Soft%20Take-over%20or%20Non-MIDI%20Mixer.html
Please note that the mixer section of the MixDeck is a real hardware mixer and does not send MIDI, so you will not see the volume sliders, gains, etc. moving in VirtualDJ. Please see: https://virtualdj.com/wiki/MixDeck.html
Posted Sat 03 Mar 12 @ 1:15 pm
So My NUMARK Mixdeck Volume Controls Are Crossed. The Decks Play How Virtual Reads Them, But I Can't Get The Volume To Switch. Left Deck Is Controlled By CH2 Gain, Treble, Mid, Low, And The Right Deck Is Controlled By CH1. I've Tried Restarting Everything, Checking To See If A Switch Was Flipped On Or Off, And Nothing Works. Someone Please Tell Me How To Fix This?
Posted Thu 17 May 12 @ 12:51 pm
Nevermind I Fixed It. Somehow In Sound Setup It Was Crossed. Left Was CH3&4, And Right Was CH 1&2. Switched It Back And It Was Fine.
Posted Thu 17 May 12 @ 2:17 pm
have you changed the source to "USB MIDI" on the mixdeck?
Posted Thu 17 May 12 @ 10:54 pm
New Problem Now. So When I'm Using Virtual DJ With My Numark Mixdeck, My Crossfader Works Fine On The Mixdeck, But It Doesn't Move On Virtual DJ. One Of The DJ's I Work With Has The Mixtrack Pro, And His Crosfader On Virtual DJ Moves When He Moves His Crossfader On The Mixtrack Pro. Any Idea Why It's Not Connected?
Posted Sat 09 Jun 12 @ 1:07 am
It doesn't move cause the mixer section isn't MIDI like the Mixtrack Pro.
Posted Sat 09 Jun 12 @ 5:54 am
