My virtual dj, in the timecode configuration shows the circles joined at the upper left hand corner.
Could somebody tell me what causes this.
And also the quality keeps fluctuating below the 100%. It drops as low as 25% while the music is playing.
How do i fix his?
How do i fix his?
Posted Fri 28 May 10 @ 6:56 pm
what kind of sound card are you using
check you cables,your gain and your needed if needed.
if it fluctuates its usually because of bad signal or too much (too loud) it should be a nice circle.
are you running the new 6.1 Demo ?
Posted Fri 28 May 10 @ 8:49 pm
I am using the trial for now.
I have the serato scratlive cd and soundcard.
In the performance menu, would changing the slider from best quality to latency affect this?
Posted Sat 29 May 10 @ 7:40 am
