Forum: Old versions
Topic: HELP PLEASE :).. HELP NEEDED WITH SOUND CARDS
I'm just in the prosess of starting a turntable timecode setup (by the way im a new to this) is it possible to hook turntables up to the laptop via a BEHRINGER BCD 2000 as a sound card or would i still need something like a maya44 to hook them up?
like i say im no expert or pro dj so would be greatfull of the help
would be thankfull for any advice
thanks
Matt
Posted Fri 28 May 10 @ 1:10 pm
also where can i find the time code vinyl?? cant find them anywhere can find the rane ones just no virtual dj ones
also is it the pro version of the software i will need?
VirtualDJ timecode records are no-longer currently available.
Serato CV02 vinyls can be used, or you might be able to find Numark VirtualVinyl records still for sale.
thanks for the info
you got any idea about the other question?
30+ veiws and no replys i presume nobody knows haha :P
Perhaps the users who have viewed so far do not use timecode and/or do not know anything about it?
To use timecode, you will need a 4-in/4-out ASIO sound card such as Hercules DJ Trim, Native Instruments Audio 4 DJ, ESI Maya44 USB, etc.
The sound card in the BCD2000 is best avoided because due to poor design it causes nothing but problems for most users.
Setup instructions and a diagram can be found on page 9 of the quick start guide: https://virtualdj.com/images/pdf/VirtualDJ6-SetupQuickGuide.pdf
For detailed configuration instructions, please see https://virtualdj.com/wiki/TimeCode%20Config.html
