hey can some one help when im djing i press the sync buttun but i dont know why one of the song stays bihind the other !! is it the turntable or is it the program.... when i check the turntable config one of them dosent get good signal ! could it be the niddle?????????????????????????????
Posted Wed 26 May 10 @ 12:41 am
u haveta be very close to it and then hit sync
Posted Wed 26 May 10 @ 1:15 am
If your using turntables why even use the sync button??
Posted Wed 26 May 10 @ 1:42 am
I didn't think LE supported timecode?
What timecode mode are you using anyway?
Posted Wed 26 May 10 @ 4:21 am
then wt can i do to get a better blend?
Posted Fri 28 May 10 @ 12:02 am
Keep praticing, lol!! No I'm just kidding. Can you beat match them yourself? If you can do that I would think that you would have more control over where you want your blends. Also are you lining up the little squares in the waves at the top of screen?? If so STOP cause they do not also match up!! And I would say trust your ears, there the BEST tools you have and they will never let you down(unless your going deaf, lol). Also what mode are you using, ABS, REL, or SMART. The sync button will not work in ABS mode.
Hope this helps
Huey
Posted Fri 28 May 10 @ 1:03 am
Hope this helps
Huey
Hope this helps
Huey
thanks man
Posted Mon 31 May 10 @ 1:38 am
