Hi
I just have virtual dj installed on my PC and I don't use an external panel to control Virtual DJ. I control it using my mouse and keyboards. Is there a way to use headphones? For example to prepare the next song witout interrupting the current?
Posted Tue 25 May 10 @ 6:05 am
By "panel" , I'm guessing you mean a controller ?
A controller is not necessary, but In order to use the headphone previewing mode with Virtual DJ, your soundcard need to be multi-channel, i.e have at least 2 stereo outputs. One will be used for your main mix ( what is controller by the Crossfader), and the other for headphone previewing.
As most laptop soundcard only provide one output, you will probably have to purchase a dedicated external soundcard. Various models are offered in every price range. Here are some examples:
http://www.djstore.com/group/soundcards.htm
Once your soundcard is installed, you will need to configure VDJ to use it. A basic configuration would look like this:
- Input : None
- Output(s): Headphone > Master: Output 1/2 / Headphone: Output 3/4
-Soundcard: (The name of your soundcard)
- Input : None
Posted Tue 25 May 10 @ 6:57 am
