I have obtained a Virtual Vinyl Timecode (Cue TSN100-3)
If I purchase Virtual DJ Pro will I be able to use it with a plain Ole Numark tt-200 via Maya 44 USB the same way it functions from a cd controller (Numark CDX)?
I currently use Torq, But i have been playing with a demo of VDJ and I'm interested in using the cdx and tt200 together....with the intention of replacing the cdx all together at some point.
Thanks...
Thanks...
Posted Tue 18 May 10 @ 9:01 pm
They will work with VDJ PRO. Hope to see you with us soon.
Huey
Huey
Posted Tue 18 May 10 @ 9:21 pm
Yes that would work fine they are the same as the Virtual DJ records.
Posted Thu 20 May 10 @ 12:11 pm
You can use your torq connectiv box. I tried it with the dem and used Rane vinyl. The torq vinyls wont work.
Posted Thu 20 May 10 @ 12:28 pm
