I just recently developed a problem where when I load a song onto a deck it has the same BPM of the song loaded in the other deck. Not sure why this started happening, but I think I must have changed something in the options. Can you get me squared away? I have pitchlock off and keylock on. In options I have auto pitch matching set to always.
Thanks for your help!
Howard
Howard
Posted Thu 13 May 10 @ 7:18 pm
Howard
Howard
You answered your own question.
Config/options auto pitch match will do this exact function.
Disable it.
Posted Thu 13 May 10 @ 7:34 pm
Thanks for your reply. Not sure if I'm having a temporary brain cramp or what, but I should have realized that.
Posted Thu 13 May 10 @ 8:38 pm
