Hi everybody!
Wednesday is going to be my 3rd official gig, only that this time round i'll be in control from 21h00 till 05h00! Anyway I went over to the club to check out their setup and it's as follows:
CD PLAYERS: Pionner 1x CDJ 1000 MK3 and 1x CDJ 1000
MIXER: I don't know the mark but it works.
etc.
I'll be using my Maya 44 sound card, Virtual DJ 6.0 and 2 VDJ TIMECODE CDs.
Here's how I set everything up in Virtual DJ:
SOUND CARD: Asio Driver: Maya44 USBAudio ASIO driver (Ultra latency checked)
OUTPUT: External mixer
INPUT: Timecodes
TIMECODE CONFIG:
> Vinyl: Virtual dj V5 CD
> Mode: Smart relative
Great! Now I can get to THE PROBLEMS and my suspicions of why this setup is giving me hell:
I believe it normal that I get that whizzing sound when I pop the timecode CDs into the CDJs. The CDJ 1000 works perfectly (the cue is fairly unresponsive) but every time I play music on the 2nd deck (CDJ 1000 MK3) I get a normal output of music BUT with the whizzing sound from the Timecode CD.
This being said, I hope the you guys can help me with my problem. This gig really means a lot to me for various reasons and I'd really like to get my stuff to work. I spent almost 3 hours trying different combinations of setup only to end up giving in to defeat... PLEASE HELP!
My assumptions and thoughts:
-Should the timecodes be burnt in a particular way? I simply used Windows Media Player
- Do I have the vinly option for the timecodes setup up incorrectly
- Do you think the problem arises from the fact that one deck is a CDJ1000 and that the other is a CDJ 1000 MK3
Thanks a lot!
etc.
INPUT: Timecodes
TIMECODE CONFIG:
Thanks a lot!
Posted Tue 11 May 10 @ 4:31 pm
You already have a topic open on this subject, to which an answer has been given:
https://virtualdj.com/forums/104382/x/
Please do not post the same question or message more than once.
Also, please ensure that you post in the correct forum, i.e: https://virtualdj.com/forums/31/Hardware_Technical_Support.html or https://virtualdj.com/forums/20/PC_Version_Technical_Support.html
Posted Wed 12 May 10 @ 12:20 pm
