so ive just loaded up with the samples for my latest set, but now im stuck with only backspin. i cant seem to get the effects to change. i click the arrow as usuall and select my effect. in this case flanger. but it just stays on backspin. i dont even know why its on backspin in the first place as i never use it. if im gonna use backspin i do it manually.
can someone please help. v6 pro. thanks.
oh and mp3 E2
oh and mp3 E2
Posted Sun 09 May 10 @ 10:59 am
anyone??
Posted Mon 10 May 10 @ 1:29 am
If you are using the PRO version, you should enter your serial number in your profile so you can download the latest updates and FX. Maybe there was a problem that has been solved since....
Posted Mon 10 May 10 @ 9:57 am
everything worked untill i loaded up a load of effects and samples. now it doesnt work.
Posted Mon 10 May 10 @ 11:49 am
