No, i don't missed! But you loaded the Skin after the meaned posting up, incl. the other resolutions. But i think, the description was already standing there, bevor it wasn#t any more possible ;-)
Posted Tue 19 Oct 10 @ 10:46 am
Since SBDJ has offered us a very usefull plugin, i just couldnt resist to update TCmania
TCmania ver 2.2
Download Link : https://virtualdj.com/addons/11460/TCmania.html
Ver 2.2
- Added Battery Status indicator
In order to work and display the battery status you will have to download the SBDJ Battery Plugin.
You will find it here : https://virtualdj.com/addons/12157/SBDJ_Battery_Status.html
When your laptop is AC powered you will see the first icon, if not (battery operation) you will see the second. If battery reaches 40% it will blink !
- Added Sampler Panel
Sampler is something i dont personaly use, but since several users asked for it, i added it as a panel . You can view the Sampler Panel by chosing it in the Pannel Selector (Multicoice button)
- Added resolution 1366X768. Now available at 1440X900 & 1366X768.
I will add one more resolution in the next update. So you will have to decide between 1920X1080 or 1920X1200. Vote !!!!
Enjoy it !
Many Thanks to SBDJ for creating tools like this.
TCmania ver 2.2
Ver 2.2
Enjoy it !
Posted Sat 30 Oct 10 @ 8:02 pm
You're welcome. If there's any other information you skin guys would like to be made available then let me know :)
Posted Sat 30 Oct 10 @ 8:30 pm
Hi Bob,
1920 x 1200 please for all the Macbook Pro users :)
Thanks
Keith
Thanks
Keith
Posted Sun 31 Oct 10 @ 3:53 am
Scott & Bob,
Tested the battery plugin this morning and it works a treat!
You can also change the percentage where the icon flashes easily in the XML if 40% is too high (or too low) for your personal taste.
Great work guys!
Keith
Great work guys!
Keith
Posted Sun 31 Oct 10 @ 6:59 am
No problem.
That makes this the first available VDJ skin with a battery meter :)
Posted Sun 31 Oct 10 @ 5:46 pm
I guess nobody plays live with the laptop unpluged, so the level baterry indicator to blink is not something that i would put lower than 50%. In fact some users might change this to 99% to blink, no matter what the battery level is, just to make sure that the laptop is AC plugged !
Posted Sun 31 Oct 10 @ 5:53 pm
Great, it only has to happen once for it to be a problem.
Posted Mon 01 Nov 10 @ 4:08 am
i vote for 1280!!
Posted Tue 02 Nov 10 @ 1:44 pm
DJ Mad Maxx wrote :
i vote for 1280!!
+1!
Posted Tue 02 Nov 10 @ 4:16 pm
update to 1280x800 resolution, waiting to be adopted downloads
Posted Tue 02 Nov 10 @ 5:26 pm
It seems that Mac Users is a minority..lol
Ok.. 1280X800 will be !
Posted Tue 02 Nov 10 @ 6:27 pm
What about the weather ?? ..lol
Really guys, i think we are full, dont you think ?
Posted Tue 02 Nov 10 @ 6:31 pm
Fantastic job, thanks for it !
Please, a 1920x1200 or 1920x1080 (my vote) that I can use it because still using the old version :-(
many thanks in advance
Posted Wed 03 Nov 10 @ 7:24 am
Hello,
Any news for a 1920x1080 ? need it :-)
thanks
thanks
Posted Fri 26 Nov 10 @ 3:37 am
Use the skin resizer and send the resulting XML to Bob. He will then make the changes and return it to you with the resized BMP. It has to be done this way due to the licensing restriction of 3 resolutions for skin creators.
Keith
Keith
Posted Fri 26 Nov 10 @ 5:57 am
Just downloaded this skin - was looking for multiple effects within the skin. Like it alot. Thanks for creating this.
Posted Fri 10 Dec 10 @ 5:25 pm
jeez Bob I'm afraid i have too many effects...this thing might blow up!! (like a Bomb!) ;-) lets see 85 sound effcts,9 vst,146 video effects + the soniques folder (85+ the G-force & whitecap)...huh...an nuclear holocaust!...haha...
Posted Sun 12 Dec 10 @ 5:28 am
Humm..are the effect panels implemented on the last 2.2 version? I'm only getting the slidder panels,not the knob panels,says must download effects which you have printed in the bmp image.culd it been the fact that i resized this to 1280x720..? or did i miss a post..
Posted Sun 12 Dec 10 @ 5:50 am
Hey Mr Effect ! I could add a few more effects but 85 ????? No way !
Posted Sun 12 Dec 10 @ 7:12 am
