Forum: VirtualDJ Skins
Topic: TCmania 2 Decks [New update ver 2.3] - Page: 5
Just a little thing for you guys to adjust you need to correct ellapsed to elapsed.
Check out our eagle eyed spell checker!! ;)
teeha teehee... lol
ok..thanks to everybody ...especially Keith for beta testing the MAc version. In the next couple of hours i will upload the TCmania ver 1.1
..elalpsed ...ok..EQ knobs..ok...corrected.
wasn't been nasty guys, just noticed something no one else had pointed out...
Ok. TCmania ver 1.1 has just been uploaded and as soon as Team approves it, you can download it here
https://virtualdj.com/addons/11460/TCmania.html
Ver 1.1
1. Added New Audio Mixer Pannel
2. Added New Rhythm Off Pannel to rest your eyes and excercise your ears
3. Added New Netsearch Video Icon
4. Fixed Font size on Mac version (uploaded seperated Mac version with all resolutions)
5. Minor graphic bugs fixed.. elapsed too ..lol
It's yours DJs. Enjoy it !!!
Thanks for your feedback. Special thanks to Keith
DjDaD... The Fun Builder !!!
What is 1355x768 resolution?
Did you mean to write 1366x768 (which is a standard size) ?
yes ..thats exactly ... 1366X768 is uploaded. Image written by mistake...eagle eye !!!!
Great ! Thanks for the job.
Is it possible to have a full HD version 1920x1080 please ?
Just downloaded the finished version and it's excellent.
Thanks for all your hard work djdad!
Keith
looks awesome and so many useful functions =)
Good job dude!
@JeremK: Oui oui, on a dejà eu des contacts, je l'ai acheté le resizer mais je préfère un skin "fabriqué" à partir des sources, la qualité est bien meilleure ;-)
Very cool skin - a fav of mine already.
It is a bit 'mouse happy', but once I figure out how to make a better mouse/keyb combo, that will be a non issue.
I do have a ? Where is the sampler section? Is it accessible and I cannot invoke it?
But still, a very nice skin. Can't wait to install in my gig rig.
i installed the new version and it's in my skin map but when i start vdj it's not under config/skins like ver 1 is.
can you tell me whats wrong.
by the way i love ver. 1 and look forward to use ver. 1.1
Important Note
After you download the Skin (Tcmania v1.1), and execute the exe, it installs in the Skins Directory a zip file named TCmania v.1.1
You have to unzip it again in the skin folder in order to create 2 more Zip files named TCmania v.1.1 PC and TCmania v.1.1 MAc. Then you may use the skin.
djdad, can i suggest you change the way you've zipped/named the files. - to eliminate the problem above.
I would do it like this:
TCMANIA (MAIN ZIP FILE)
skin - WINDOWS.xml
skin - MAC.xml
By doing it this way for your resolutions it will mean that the install file downloaded will install without having to UNZIP things seperately, which might complicate things with some user.
When i uploaded the skin i uploaded 2 seperated zip files 1 for PC and 1 for MAc, zipped together in 1 bigger zip file. I thought at the beggining that Team would seperate these 2 zip files and create 2 seperate exe (1 for PC and 1 for Mac). But i was told by Team that since the skin it's approved the procedure is automatically, so i just didnt noticed that before i download my own skin ..lol..
The main reason i did that, is users to be able to download just the skin you need (PC or MAc) and not the whole package...anyway my bad.
Ah i see. You could do what you've done but not zip the two internal folders - that way if a Windows users wanted to delete Mac skins they could just delete that folder or vice-versa.
Probably an easier solution than my last one. Just leave it all as it is now - just dont zip the windows and mac folders.
ok.. i have just reuploaded the skin, so..
for those who have allready downloaded the skin unzip the file again as described couple of posts above...
for those who are going to download the skin, everything is perfect. It installs both PC and MAc versions (totaly 10 dif resolutions) without doing anything.
Sorry for the mess.
63%
