sometimes when I try to adjust the pitch control it becomes unresponsive and I have to slide it up and down very rapidly in order for it to adjust the BPM.It works fine for a while but then starts acting up again.Also is there a way to adjust the sensitivity of the pitch control slider?
Im not sure what other info you guys would need so I included the following
im using VDJ v6.0.7 pro along with the Xponent.
Posted Wed 05 May 10 @ 10:44 pm
Turn off "pitch reset on load" in the options.
Posted Thu 06 May 10 @ 11:55 am
that worked but is there a way to adjust the sensitivity cause it jump as soon as i touch the slider
Posted Fri 07 May 10 @ 11:59 pm
On the options tab (or on the skin depending on which one you are using) increase the pitch range. This will slow the movement of the slider.
Cheers,
Roy
Cheers,
Roy
Posted Sat 08 May 10 @ 2:20 am
The Xponent pitch control is very light and poorly weighted which doesn't help.
Posted Sat 08 May 10 @ 7:41 pm
you right,when I first got it the first thing I noticed is that there is very little resistance on them
Posted Sat 08 May 10 @ 11:06 pm
Cheers,
Roy
thanks.
Cheers,
Roy
thanks.
Posted Sat 08 May 10 @ 11:07 pm
