Any recommendations for microphones to use with Hercules RMX? The one I have is too simple and does not provide enough output.
Thank you in advance.
Posted Wed 05 May 10 @ 12:34 pm
Shure SM-58. Industry standard vocal mic. Are you plugging the rmx directly into an amp or powered speakers? If you are running it into a mixer, you should be running your mic into the mixer, too. The RMX has a fairly low mic output, in my experience.
Posted Wed 05 May 10 @ 9:06 pm
^^^^^Agreed with everything in the previous post.^^^^^
Posted Wed 05 May 10 @ 9:47 pm
Most def. Shure Sm58. Period.
Posted Wed 05 May 10 @ 10:30 pm
+1 Ditto
Posted Wed 05 May 10 @ 10:45 pm
Perfect. Thank you. I'm aware of the limited output from the RMX, but if I'm buying a new mic, I would like it to work directly from the RMX if possible. According to Hercules, I should choose one with 600 ohm. The Sure SM58 only has 300 ohm. But if you have tried the SM58 directly from the RMX and that works, then I will go for that one.
Posted Wed 05 May 10 @ 11:52 pm
Well if you plug your Shure SM58 directly into the mic input, it won't work (the volume will be very VERY low), because of the impedenca difference thing-y.
One solution would be to buy an external mixer or this (like I did): http://www.behringer.com/EN/Products/MIC100.aspx
However you will still have a problem if you wish to record/broadcast your mix, since the mic volume will still be quite low, when recording, don't really know the solution to this problem... You might have a better time not buying the mic before you got the money for an small external mixer too.
Cheers!
Cheers!
Posted Thu 06 May 10 @ 4:20 am
This little tutorial might help:
https://virtualdj.com/homepage/Made_In_Breizh/blogs/4082/Record_DJ_Console_Rmx_microphone_input_in_VirtualDJ.html
Posted Thu 06 May 10 @ 6:16 am
Hello Perragnar,
a) Can you precise where you read this information that you should use a 600 ohm microphone on the Rmx?
In my opinion, it is definitely not true and it is a mistake, a limited impedance generally provides a louder ouptu, so you should not go over 100 ohms for the microphone, except if your microphone has a high sensibility, otherwhise the output will be low.
b) I have tested the SM-58 on an Rmx and it works but the output volume is too low. A work-around is to use the SM-58 as audio source instead of using it in talk-over mode, as in ther link of Phatso:
- 1: set microphone as input 1-2 in DJ Console Rmx control panel,
- 2: activate the microphone input with “Source 1” button instead of the Mic On/Off button of the Rmx,
- 3: set the microphone volume on the microphone volume button,
- 4: add gain with DJ Console Rmx left deck gain button
to get a louder volume when using your microphone on DJ Console Rmx (since the gain button adds an additional gain - VirtualDJ software gain – compared to the talk-over mode on DJ Console Rmx) In this way, you lose the talk-over mode, but you get an additional software gain.
c) I have a microphone whose specification is too far from SM-58, but whose output is much stronger, it is Stagg MD-1500 (600 ohms).
Posted Thu 06 May 10 @ 8:10 am
Microphone use in RMX is already on Wiki.
https://virtualdj.com/wiki/Hercules.html
Posted Thu 06 May 10 @ 3:10 pm
Perfect. Many thanks!
Posted Sun 09 May 10 @ 2:22 pm
