How to change the language of Virtual dj software??? Pls help
Posted Wed 05 May 10 @ 1:05 am
Good question. The only place I have seen an option for language selection is when you launch the program for the very first time & it offers you to select a language but I believe English is set by default if you don't select something different.
Also just realized that if you to Config, Skins tab, look on the right to the drop down & you should be able to change it. Hope that helps.
Posted Wed 05 May 10 @ 2:20 am
