Hey,
So I have Virtual DJ 6 and I'm using Serato Scratch Live timecode vinyls with my Hercules DJ RMX console as my ASIO card and it works PERFECT...minus one problem. When the needle is not on the vinyl or i stop the record the vinyl when im trying to cue something up on the computer it automatically starts to jump all over the place in the song so its hard to really hard to cue stuff up for beat matching. It is as if when NOTHING is touching the vinyl that im moving the record violently all over the place on the computer screen. This happened recently; it was working perfectly fine for a few days with the same equipment. I would appreciate any help.
Here a pictures of my settings:
http://s768.photobucket.com/albums/xx322/senrux/?action=view¤t=vdj1.jpg
http://s768.photobucket.com/albums/xx322/senrux/?action=view¤t=vd2.jpg
http://s768.photobucket.com/albums/xx322/senrux/?action=view¤t=vdjupload1.jpg
My other equipment:
-Toshiba laptop 1.5 gig rams (old, but runs vdj fine for me)
-Two numark tt1625 (crappy turntables i know, but i don't think it's the problem)
I appreciate everyones help!
Thanks
My other equipment:
Thanks
Posted Wed 05 May 10 @ 12:14 am
@ Senrux
Use the SILENCE knob to add a little dead zone on the center . When stopping the record, this will prevent it from "jumping all over the place".
Posted Wed 05 May 10 @ 6:32 am
thank you guys very much for your help! Yep, all i needed was a little bit of silence at it was good to go!
You guys rock!
You guys rock!
Posted Wed 05 May 10 @ 1:50 pm
