I was looking to buy a really cheap external soundcard for just bedroom or small party use, with a laptop, hercules mp3 e2 and some headphones. I know the Dj io soundcard and Maya44 are recommended, but for this type of use does it really matter which soundcard you use as long as it has front and rear R L outlets?
Posted Tue 04 May 10 @ 12:39 pm
For small party, if you are not using time-codes, I would use any hercules with a built in sound card. I still use my MK2 for small parties.
Posted Tue 04 May 10 @ 2:55 pm
The Maya44 is better suited to timecode or external mixer use.
Either the Numark DJIO or Native Instruments Audio 2 DJ would meet your needs.
Posted Tue 04 May 10 @ 4:17 pm
if u are using the external sound card for headphones,ive used 2 different tyoes of creative soundblaster soundcards and didnt have much trobule with either
Posted Tue 04 May 10 @ 8:29 pm
Thanks guys, I already had a cheap £12 soundcard being posted from a mates which I bought so I dont know if thats going to be any good as a temp solution, was looking at the dj io as a longer term solution as it is recommended by VDJ
Posted Wed 05 May 10 @ 4:19 am
