is there a time stretch on virtual dj if so how do i enable it to work so that i can speed up my voice track withot it becoming squeeky or slow it down without it becomming a deep scary voice? your help would be greatly appreciated :)
Posted Thu 29 Apr 10 @ 9:39 am
nobody ? :(
Posted Thu 29 Apr 10 @ 9:42 am
If I am reading correctly. You are trying to stretch or contract the audio but keep it from changing the audio... I would think you are just trying to speed up or slow down using the pitch. You need to enable Key Lock, and the software will keep the audio frequencies the same but allow you to change the timing.
Posted Thu 29 Apr 10 @ 10:08 am
You read correctly and you responded correctly thank you verry much my friend :) it worked
Posted Thu 29 Apr 10 @ 10:38 am
have ur keylock on
Posted Thu 29 Apr 10 @ 4:55 pm
