I need to create a script to allow me to use loop 0.5 initially and after like the loop is repeated to 3 times to go to loop 0.25 and so on Is that possible?
Posted Tue 27 Apr 10 @ 2:13 pm
Sorry, it's not possible to do that with VDJscript.
You can manually half or double the loop by assigning keys or MIDI buttons to loop_half and loop_double
It might be possible with a custom written plugin though (C++)
Posted Tue 27 Apr 10 @ 4:48 pm
O.K
Posted Tue 27 Apr 10 @ 5:58 pm
sounds like you should check out the beat grid plugin.
Posted Tue 27 Apr 10 @ 7:54 pm
How can I program it to work that way?
Posted Tue 27 Apr 10 @ 9:32 pm
