I just update tp 6.07 version & having two issues
1 - when loading a video or music file the audio output is fine but screen freezes for a few seconds & then the file starts to load.
2 - when I start the program the files load all the way but when the program is runing for about two hours into it the files only load very little then while playing that file it load a few seconds ahead & keeps repeating the same thing as the file is playing.
Any suggetions or input on how to fix this. Before the update I was using 5.07 & never an issue.
Posted Sun 25 Apr 10 @ 12:49 pm
you might get more help if you give us the specs on your system....
Posted Sun 25 Apr 10 @ 4:41 pm
i Seem to have a very similar issue as above BUT mine is a bit worse im affraid. Last night in running a sweet 16, i had a freezed up pc and "scratchy" music coming out while monitor was frozen. I had to reboot the program. Luckily i was able to be up & running in 2 min, but i sure did ALOT of bs talking to keep them into it, lol. Seems like the letency got thrown off but also i noted through the performance, VDJ was running on half or 3/4 bar (CPU usage bar on VDJ Screen). for the record, i had the internet connection off and ALL firewall/security software off. At times, it ran dangerously close to shutting down again. Please help in fixing this issue as i really dont want to go thru this embarrasing moment again.
Specs for my laptop are as follows:
Toshiba laptop (18' monitor)
Windows 7 O/S 64 Bit
6gb Ram
500Gb hd(in case its needed)
Intel core duo
Music system connected:
2 x Denon 3700 - Latest update for denon installed
Denon ASIO soundcard - latest version installed
External mixer with no digital in/outputas i use ASIO from denon.
VDJ 6.0.8
If you need any other spec, let me know. Looking forward to some H E L P!!!
6gb Ram
Intel core duo
VDJ 6.0.8
Posted Sun 02 May 10 @ 10:38 am
