hey all im about to purchase some cdj 800s was wondering if using the maya 88 usb would be good to support my mixer the 800s and the laptop im using......also i assuming i got to dl the timcoded cds so the cdj's will cue up on my virtual dj......i was also wondering will my preset que points that i stored in vdj will they show up on the cdj once i have the timecoded cds in
Posted Sun 25 Apr 10 @ 10:33 am
Have you ever thought about another deck like the DEnon 3700's. You wouldnt have to buy the Maya 44 if you had the denons. I had Pioneer CDJ 1000mk3's and i sold it it to buy the 3700's. They are really good. You dont have to pay 899 if the price seems high.
http://www.sonicelectronix.com/item_18569_Denon+DJ+DN-S3700.html this for 799
http://www.proaudiostar.com/servlet/the-5480/Denon-DN-dsh-S3700/Detail Even though it says 899, Call them up to get a better price. I paid 740 each deck last year
What makes the DEnons better is that you can use it native, You can also use time codes cd's or download the time code signal into a usb stick. The Jog wheel is way better too. I scratched on 1200's, Numark cdx tables, Pionner cdj's etc and the denons feel really good.
Posted Sun 25 Apr 10 @ 1:24 pm
thx man i can get a pair of cdj 800s for 700 each so i think im still going to go with the pioneers......so i will need the maya 44 then correct???? also will the cue points that i have made in vdj show up on the screen on the cdj 800 once i get everything set time codes and all
Posted Sun 25 Apr 10 @ 2:14 pm
Anything you do on virtual dj, it doesnt show up on the CDJ 800's. The CDJ 800's are for playing CDs and time codes. You can't control virtual dj native with these decks. The Decks has to have a USB port. Pioneer CDJ 400's have then, Denon 3700's have them and the new Numark decks have them too. The maya 44 is ok but get the M-Audio Connectiv sound card. Its sounds alot better
Posted Sun 25 Apr 10 @ 6:32 pm
i got another question man if you cant control vdj with the pioneer cdj's then how were you running your pioneer cdj's with vdj i thought if you buy the timecoded cd's it will all cue up in vdj......also i have looked at the denon's pretty cool stuff......correct me if im wrong but from what your saying usb is the only thing that will cue up to all the functions of vdj....timecodes wont????
Posted Sun 25 Apr 10 @ 9:10 pm
I was using the Pioneer cdjs with time codes. I had my songs cued up in the software and i triggered them on the laptop with the keyboard short cuts.
Posted Sun 25 Apr 10 @ 11:30 pm
so basically if im running timecodes with the 800s if i press play on the cdj it wont show up in vdj....ill have to press play in vdj....b/c i too have all my songs cue'd up in the virtual dj software.....what i hearing is that i cant control the software with the 800s even if i have timecodes is this correct??? i will need a cdj with a usb to control the vdj software????
Posted Mon 26 Apr 10 @ 9:52 am
