Hello again forum!
Now I'm the somewhat proud owner of a Hercules RMX and a Shure SM58s microphone I bought the other day. I noticed that the microphone was very quite (eventhou the volume knob was put on max) and that VDJ wouldn't record/broadcast the input from the microphone.
I read a couple of posts on this forum, and saw that this was apperently a common problem because the RMX doesn't support mic's with and impedance above somewhere along the lines of 100 Ohm, and I noticed that the Shure SM58s is a mic with 300 Ohm impedence.
Now, one of the posts said a solution would be to buy the Behringer MIC100 microphone preamplifier
(http://www.amazon.com/Behringer-MIC100-Vacuum-Preamplifier-Limiter/dp/B000CZ0RME/ref=sr_1_1?ie=UTF8&s=electronics&qid=1272044273&sr=8-1)
and make the microphone run through preamplifier, and the preamplifier through the Hercules RMX mic input, but can anybody support this?
My technological knowledge is quite low, so I can't say I'm sure what a preamplifier does, and if this will fix the problem, but I thought I would ask the wonderful forum before I went & spent 46 euro's on this thing :)
TL;DR - Is the formel presented in the title correct ?
Many thanks in advance!
Cheers!
-Mikkel
Cheers!
-Mikkel
Posted Fri 23 Apr 10 @ 12:42 pm
