Does anyone know if its possible to hook up a behringer tweakalizer to a hercules rmx dj console?
Posted Thu 22 Apr 10 @ 7:50 pm
Ha,ha...good one!! this guys probably think Behringer is Low end...but the Tweakalizer is a great box ! havent al my old gear its in storage but..SURE ...you could add the Tweakalizer on the outputs of the RMX if youre going to a sound system or if your using the RMX aas a sound card and you youre outputing channels A & B (1 &2 ) into another mixer that has efffects in/out ,you can plug it there BUT the RMX doesnt have external effects loop I'm afraid...theyre cheap (@ $99 U.S.A.) so you could get 2, one for each turntable channel..
Posted Thu 22 Apr 10 @ 8:58 pm
WtF are you talking about? where do i get a rmx for 99 bucks? is there a website?
Posted Thu 22 Apr 10 @ 9:21 pm
Ha,ha dream on home boy !! were talking about the Tweakalizer Effect unit by Behringer.THATS $99 here in the states.with audio in & outs you can hook it up to anything. meant for Turntables & mixer setups but ive played my guitar thru it !! Great Resonance filter with Lfo & bpm sync! also a Sampler,flanger,echo,...cool. though its bpm sync its not as accurate as VDJ since it dealing witha anolog audio signal and not a digital wave..
Posted Thu 22 Apr 10 @ 9:34 pm
