Does the Native Instruments Audio 8 DJ USB Midi Interface works great and perfectly with VDJ using CDJs and timecoded cds??
Posted Wed 21 Apr 10 @ 2:24 pm
And wat abt the Native Instruments Audio 4 DJ USB too?
Cheers
Cheers
Posted Wed 21 Apr 10 @ 2:27 pm
both soundcards work good with VDJ.
Posted Wed 21 Apr 10 @ 4:27 pm
Sischo do you go from the MIDI out of the Audio 8 to the USB of your computer OR do you go from the MIDI in of the Audio 8 to the MIDI out of the DJM 800?
Posted Fri 30 Apr 10 @ 12:12 pm
Do you need to hook up your DJM 800 to your computer?
If so,
1) you can hook up the Audio 8 to your computer by the usb cable and the mixer (by MIDI out) to your sound card (by MIDI in)
2) you can hook up the Audio 8 to your computer by the usb cable and the mixer to your computer by another usb cable (MIDI-USB adapter).
Enjoy.
If so,
Enjoy.
Posted Fri 30 Apr 10 @ 3:24 pm
Do u guys reckon using this soundcard wiz VDJ in a club??
And wat cds do u use,the VDJ timecoded one??
And wat abt the RCA cables,is it the normal one??
Posted Fri 07 May 10 @ 7:11 am
Yes, soundcard works great, CD timecode serato and normal RCA cables.
Posted Fri 07 May 10 @ 5:42 pm
