Hey all! Just bought myself a numark omni control! its sick! and i recommend it completely!
One problem, im having trouble setting it up so i can plug my headphones into the port on the omni control and use it to cue, even if i could plug it into my computer it'd be better than nothing! The omni control is only plugged into the computer via usb and the speakers are connected through my an auxiliary cable from the cd player they are connected to, so there is one plug going into my pc to place the sound.
Anyone go any ideas how to set it up? cheers.
Posted Mon 19 Apr 10 @ 3:13 pm
i couldnt even get my omni control running on virtual dj, kept saying to many channels lol so im not sure as i didnt get that far.. but start by making sure in control panel your audio output is your omni device and that way your speakers and headphones should work through you omni control..
your 3 center knobs PH VOL PH MIX AND MASTER... make sure your PH MIX is on "cue" then its just a case of using PFL on the channel you want to use and turning PFL off the 1 channel you dont
other than that im not to sure as i cant seem to get mine running on virtual dj atall so cant see what settings you need sorry
Posted Tue 27 Jul 10 @ 3:46 pm
