well said hippy ......
Posted Mon 19 Apr 10 @ 1:39 pm
Yes +1 for the sound snippet problem.
Also the biggest bug for me it's with waveforms not loading completely after playing videos for several hours on win 7 64 bit machine. Hopefully it gets addressed soon!
Thanks for the update.
Posted Mon 19 Apr 10 @ 1:53 pm
suweet!
Posted Mon 19 Apr 10 @ 4:34 pm
Thanks for the update. Just what the NS7 needed. No more pitch drifting!!! Scratching, Beat juggling is on point even with videos!
Posted Mon 19 Apr 10 @ 4:37 pm
GadgetMan wrote :
Please note the original post: This is a very focused release which was able to bring support for new controllers and improve the response on existing controllers with motorised platters - There was no mention of the solving of any video issues in this release.
Please also use the Wishes and new features forum to make requests for future improvements where, if you check, you will see that this has been asked for many times already.
Cheers,
Roy
Cheers,
Roy
Have been waiting for over a year for proper support for the Allen & Heath Xone 3d
Posted Mon 19 Apr 10 @ 5:58 pm
The Xone mixers are simple MIDI devices and can be mapped easily using the simple MIDI mapper.
If you are so inclined a definition file can be created for it if you are willing to provide the information.
Posted Mon 19 Apr 10 @ 6:57 pm
Cheers Atomix.
You fixed netsearch, its helped me out many a time to plug tracks that have dissapeared from my harddive over the years.
and i got my wish about MSN. (When VDJ in in the foreground, to automaticaly make MSN into BUSY mode. this stops the MSN sounds)
many thanks.
Continuing to test before my next gig on Wed-nite :)
many thanks.
Posted Mon 19 Apr 10 @ 7:20 pm
Thankz VDj I Will Test It Out Sat & Sun See How Well It Work Out For Me LIVE.
Posted Mon 19 Apr 10 @ 7:43 pm
Very Nice the Wow and Flutter is Gone!
Posted Mon 19 Apr 10 @ 10:34 pm
Still got problem playing a lot of my video files. Some are mpg and some are avi/xvid. They freezes, the picture are out of sync with the sound. I even got one video to play sound from one file and show the picture from another!!
Switching to windows media player codec takes away the freezing of videos but when i load a video the waveforms freezes a few seconds instead.
Yes i always make clean installs!
All of these videos works well in v6.0.4 and in other players/applications but not in 6.0.5, 6.0.7 and not in 6.0.8 as many before me mentioned. I use vdj with NS7 so i want the improvements in v6.0.8 for NS7, but i still want to be able to play my videos. Well back to 6.04 again.
Posted Mon 19 Apr 10 @ 11:35 pm
I would like to add that my video problems as stated in my previous posts (program locking out when trying to deactivate video while playing video) began in vdj 6.05 as well.
Posted Tue 20 Apr 10 @ 12:11 am
Before complaining that video problems still exist for you, I would recommend that you read the changelog along with other posts in this thread (there are no video engine fixes mentioned in the changelog) and then continue those discussions on the already existing relevant threads rather than polluting another.
Thankyou :)
Thankyou :)
Posted Tue 20 Apr 10 @ 4:41 am
They cant be easily programmed (well I cant do it anyway despite many attempts, I have tried in vain with the help of others for over a year to get the jogwheels to operate correctly. I posted on the forum and provided all the information about the midi signals but never got anywhere.
Posted Tue 20 Apr 10 @ 10:28 am
I have this with Vista this is an old problem not just with Windows 7. With v6.0.7 the problem got worse normally I would see this problem until after play for 6 or 7 hours after v6.0.7 it started happening after an hour or so into playing.
One thing I did which seems to have solved the problem (for the most part) with v6.0.7 was turning Netsearch off and I used the registry tool for the video freeze problem. Haven't tried v6.0.8 to see if there is any improvement in the time you play before the waveforms no longer completely load.
edit - removed quote sorry Hippy didn't know
Posted Tue 20 Apr 10 @ 2:18 pm
Runs alot smoother with less clips and pops.
Posted Tue 20 Apr 10 @ 4:31 pm
I'm willing to try and help you sort it if you want; feel free to drop me a PM either on here or over on MDJF.
Does this mapper (for v6) not work then?
http://www.virtualdj.com/addons/9827/Allen___Heath_Xone_3D_Def___Mapper.html
Posted Tue 20 Apr 10 @ 6:05 pm
I cant wait to try it, my HS 5500's have been dead in the water since last update :)
Posted Wed 21 Apr 10 @ 1:15 am
same here, but Denon is alive again :) !!!!!!!!!!!
perfect work dudes!!!
Posted Wed 21 Apr 10 @ 1:23 am
Yes it does to a point but the crossfader isnt mapped, which I need for video crossfade. I also need to change the layout of a few controls. I pm'd the maker but he didnt get back to me.
Posted Wed 21 Apr 10 @ 9:11 am
does anybody know if u have serato and the new vdj pro installed on the same laptop, do u know if one program deletes the comments written by the other?
Posted Wed 21 Apr 10 @ 10:38 am
