my question is can i use the program on more then 1 machine. I own a laptop that i use for work but I do alot of organizing on my home pc.
Posted Thu 15 Apr 10 @ 9:05 pm
You sure can no probs at all, it's exactly what most of do. And welcome to the community.
Posted Fri 16 Apr 10 @ 3:27 am
isnt that a licensing violation?
Posted Tue 20 Apr 10 @ 6:24 pm
That's what I would think....
Tayla can you expand on this further as I would like to know the answer to this just like the OP.
Posted Tue 20 Apr 10 @ 7:08 pm
This is an extract from my VDJ pro EULA...
You are granted one license to:
- install and use the Software on one computer.
- install and use the Software on a second computer, if this computer is normally used by the same person and the Software will not be used on both computers at the same time.
- make back-up copies of the Software for archival purposes.
I'm not sure if this is different for trial or limited users, but think its the same.
Posted Tue 20 Apr 10 @ 7:36 pm
Thanks for looking that up for all us that don't read the EULA. That's good information to know when I do end up purchasing a PRO license.
Posted Tue 20 Apr 10 @ 7:45 pm
