Forum: Old versions
Topic: Numark Mixdeck with virtual DJ - Page: 2
Hi all
I have been having the same problems with the lights when I use the mini side of the mix deck. They go completely off. Do you guys know how to fix that?
Thanks
i have a mixdeck with virtauldj 7.0.1 and a get a pausein when the song is playin i no the latency is off how to fix that ? any one can help
Hi all
Thanks
well what i do is turn down the amp and increase the volume on the mixdeck..that way i can regulate the sound better..and the lights work fine then
my laptop was pausing too like that...i noticed i had the wi fi on and when i turned it off it stopped pausing...hope that helps
I purchased the numark mix deck and I am running Virtual Dj Pro 7 on a Mac. I love it. My question is when I am playing MP3's from my MacBook how do I record samples and play them throughout my set on the mix deck ?
Hey i just got the mixdeck.. i connect everything according to the setup guide. i have no control, i get audio but i cant control anything from the mixdeck. im using vdj 6.0.1, i got a vdj le but that doesnt open at all it gives me and error saying the controller has not been detected please plug in the controller and start virtualdj again.. please help.. thank you
VirtualDJ v6.0.1 is too old and does not support the MixDeck. There have been numerous changes and improvements to the software since this very old version.
You will need to use the latest VirtualDJ Pro v7.0.2 or the free version that comes with the MixDeck. You can upgrade to VirtualDJ Pro at a discount by going to https://virtualdj.com/buy/
If you can't get the free LE version to work, please download the most recent LE version from Download Center https://virtualdj.com/download/updates.html and ensure that you have the latest drivers and firmware for the MixDeck installed from http://www.numark.com/mixdeck
Question: when you guys say "mappers are only available to registered licensed users who have purchased VirtualDJ Professional"... is it required to purchase the PRO version specifically or can you purchase the BASIC version in order to get the mappers working correctly with VDJ7?
Thanks.
Never mind... I answered my own question.... by looking at the comparison software chart, it shows the the BASIC version does not support 'MIDI/HID Controller/Mixer'. The PRO version would be required to to setup the proper mappers with the Numark Mixdeck controller.
The full VirtualDJ Professional is required to be able to use MIDI/HID controllers and download and use any custom mappers. VirtualDJ Basic is for mouse/keyboard mixing only.
The MixDeck is natively supported in the latest VirtualDJ Professional which now that you are a Pro user you can download from https://virtualdj.com/download/updates.html
I just bought the numark mixtrack pro and as I was installing VDJ, a message popped up and said my computer was to old. I own a mac OS 10.4.11 and I just realized I needed at least a 10.5 to run my controller. Is there any type of download I can get or an older version of VDJ that will work with my computer?
Thanks
Sorry, the MixTrack Pro is not compatible with this old operating system.
The minimum requirements are MacOS 10.5 with an Intel Processor - Please see the technical specifications at http://www.numark.com/mixtrackpro (These should also be on the product's box.)
There are no downloads or older versions available. You will need to upgrade your Mac to Leopard or Snow Leopard, or purchase a new computer if it does not have an Intel CPU.
I am afraid that is not possible :-)
Numark wrote :
MINIMUM COMPUTER REQUIREMENTS
Mac: OS X 10.5, Intel Core Duo 1.66 GHz
Upps: Sorry - Too late! ;-)
IM HAVING A BIG PROBLEM WITH MY VIRTUAL DJ.....I HAVE THE PRO VERSION AND EVERYTHING WAS WORKING FINE....BUT NOW WHEN I TRY AND GO CHANGE THE SOUNDCARD SETTING TO "NUMARK MIXDECK" IT DOESNT SHOW UP ANYMORE.....EVERYTHING IS SET UP FINE AND LIKE I SAID IT WAS FORKING FINE ONE DAY THEN THE NEXT IT DIDNT....IDK IF ANYONE ELSE IS HAVING THIS PROBLEM...OR IF MY MAC ISNT RECOGNIZING THE DEVICE? IDK!!! SOMEONE PLEASE HELP!!
My Numark MIXDECK isn't coming up as an audio device when I go into "Audio MIDI Setup" on my MacBook Pro (OS X 10.6.6). I have downloaded and updated my VirtualDJ to its full capacity, and I'm running the free trial Pro version. I don't believe there's a problem with the VirtualDJ, but I do believe that the problem is with the Numark MIXDECK. I plug the controller into the USB and everything, nothing pops up. Is there anyone that can help me? I'm DJing a party on Saturday, and I need help please.
I just bought the Numark Mixdeck with (Limited Edition vDJ) so i was guessing everything would work properly.. and im sure it probably does but my main problem is that the, Crossfader (specially) Bass, Mid, Treble, and Gain arn't working everything is up to date so idk wuts the problem :/ does anyone have a solution to making this work
@DJGONE,
with the mixdeck u won't actually see the knobs turning in VDJ with the mixdeck because the way the mixer is setup. But use your ears 2 see if u can hear it. I think the eq & crossfader movements show up in VDJ because I think the mixer on the mixdeck is setup as midi & not usb.
Half Right RD, DJGONE the mixer is a NOT MIDI. Nothing you do will make the knobs and slider move on the screen. The ONLY part the is midi is the 2 decks and that's only when in midi mode. You have to treat it like an ext. mixer (hence you pick ext mixer in the sound setup). So yes like RD said you should be able to hear the differences when you adjust gain, eq, etc, on the mixer.
Hope that helps, just shoot me a Pm if you need help
Huey
78%
