When I was using VDJ 5.02 i was using mappers that worked well for the Numark DMC2 and The Hercules MK2. With 6.07 i can't get the same feature with the headphone mix. I am trying to have the touch of the jog wheels cue the headphone for that side into the headphones.
Can someone tell me how to set the mapper to do this? The decks were not split in the headphones, but the song would play from the deck for whichever jog wheel i moved slightly.
Posted Wed 14 Apr 10 @ 3:23 am
I have a separate sound card for the audio out to the main speakers. i am using the hercules sound card for the headphones. How can I get to cue the song by just touching the jog wheel?
Posted Wed 14 Apr 10 @ 4:17 am
I can t even get the Hercules to split both decks into the headphones.
Posted Wed 14 Apr 10 @ 5:02 am
Can anyone please help?. I need to have music qued through my headphones for this weekend!
Posted Wed 14 Apr 10 @ 11:08 am
This has to be a mapping issue, because it works in 5.02 but not in 6.07 with the new mappers. Help anyone!
Posted Wed 14 Apr 10 @ 11:50 am
Check the CONFIG -> Options -> Auto Headphones setting.
When set to On Load, it will set the selected deck when you load a song on to it.
When set to Always, it will also set it when you scratch on a deck.
Alternatively, you can go to CONFIG -> Mappers, choose the DMC-2 in the drop-down list, then scroll through the mappings to find the jogwheel mapping.
Change it to:
jogwheel & select
Do the same for the Hercules if you want the jogwheel on that controller to do the same.
Change it to:
jogwheel & select
Posted Wed 14 Apr 10 @ 12:40 pm
I have it set exactly the same in both 5.02 and 6.07 however it doesn t work in 6.07
Auto Cue - Enabled
Auto Headphone - Always
Auto Cue - Enabled
Posted Wed 14 Apr 10 @ 12:50 pm
Try the above mapping change to force it.
Posted Wed 14 Apr 10 @ 1:18 pm
Thankyou...Thankyou...Thankyou!!!!!!!!! i have spent 2 days trying to figure this out and stayed with version 5.02 for a year because i could not figure it out...... Did I say thankyou!?
The problem was with the mapping. Mapping the wheel with Jogwheel & Select fixed it.
Posted Wed 14 Apr 10 @ 1:21 pm
You should have asked in the forums earlier :)
Posted Wed 14 Apr 10 @ 5:34 pm
