is there a way that i can play a list of songs. like say i have to run out do something use the bathroom what ever the reason can i choose a list of songs and walk away for a little bit.
Posted Tue 13 Apr 10 @ 2:16 pm
yes, there is a auto play option that will allow you to cue up multiple tracks to play while you head to the bar/restroom/backroom/smoke-break.
Download the user manual and see page 15 for info on playlists and automix.
good luck.
good luck.
Posted Tue 13 Apr 10 @ 2:21 pm
Look at this tread (Automix)
https://virtualdj.com/forums/75527/General_Discussion/AUTOMIX_SHORTCUT_(For_those_who_miss_the_Automix_button_in_skin___).html?highlight=automix%20shortcut
Peace,
James
Peace,
James
Posted Tue 13 Apr 10 @ 2:24 pm
@ricky, yes there is, you could run out and rob a bank if you want (not condoned mind you or encouraged) set up your playlist in the right hand coloumn and hit play or double click on the top title and it will automatically play through the list.
Posted Tue 13 Apr 10 @ 8:09 pm
