I am trying to find the shortcut for loading a song to a deck. I made S go to the search window, and i can then arow up and down, but I cant find a "load to deck" or something like that. I do NOT want to load from a playlist, but from a search window. It's gotta be there, most hardware had a "load" button.
thanks- Dave
thanks- Dave
Posted Fri 09 Apr 10 @ 12:19 pm
action-learn
deck 1 load
deck 2 load
Braenzu
deck 1 load
deck 2 load
Braenzu
Posted Fri 09 Apr 10 @ 12:28 pm
I must be going crazy, but I dont find that under the keyboard shortcuts?
Posted Mon 19 Apr 10 @ 3:21 pm
Hi. You could use 'enter' key on your keyboard (it loads a song to deck). If you want to map another key you can use 'load' or 'browser_enter' verb. I would use 'browser_enter' because using 'load' when you are focused on folders window will load the first song that is in the focused folder. When using 'browser_enter' if you are focused on the folders window it will focuse on the songs window first than will load the song if you press that key one more time. Here are some pics withe the action...it's there :)
Posted Mon 19 Apr 10 @ 4:13 pm
