Hiya could anybody help me im using virtual dj v5.2 pro my laptop is running windows vista and has a dual core prosesor with 2gb of memory i play in lots of venues who all use pioneer cdj 800's and an allen & heath mixer i get the same problem in all the venues except one venue where it works perfect i use the Native Instruments audio 4dj with the multi-core cables and timecoded cd's the problem that i get is that when i play deck 'B' it will not return to the begining of the track ive loaded after ive played some of the track and pressed the cue button on the cdj and will sometimes even stop all together after about 30 seconds of play without me pressing anything while using the two cdj's but deck 'a' works perfect it also works perfect if i set it up to run in single timecode mode (in the settings both decks are set the same)
Posted Thu 01 Apr 10 @ 12:11 pm
