Hi guys,
I'm running two numark tt200's with serato cv02 timecoded vinyls. I'm using my Mk2 as a soundcard with Macbook 4gb ram.
However, I'm running into a slight problem... There's significant pitch drifting on the tracks that I play through vdj. I checked my timecode config option and my timecode circles are red and slightly elliptical (even though it says timecode 100%). I was wondering... How do I modify the timecode signal through the mk2 in order to get a perfectly circular timecode signal? Maybe something like the knobs on the serato box?
And also, are there any soundcard latency settings that I could change for better performance?
Thanks in advance!
Thanks in advance!
Posted Tue 30 Mar 10 @ 10:05 pm
