I've migrated over to mac with a new MB Pro running Snow Leopard. I was using a Maya44 USB with my PC which is OK for outputs under VDJ 6.0.7, however the inputs are just not working and from what I can gather (correct me if I'm wrong) there are problems for all ESI cards under Snow Leopard.
So, my questions are:
- What soundcard can be recommeded for this setup? I've been looking at:
M-Audio Fast Track Ultra
M-Audio Connectiv (horrible design and plasticky, but does have the photo preamp bypass in it which is handy)
Hercules Trim (anyone advise on the sound quality of this card?)
Edirol FA-101
- Has anyone had success with timecode bypass? I've tried this using the Maya on my PC but the sound quality playing vinyl through the PC was awful. I have a couple of phono switches to physically bypass the signal to the mixer, but it would be easier if I didn't have to use these
Thanks a lot
roki
Edirol FA-101
Thanks a lot
roki
Posted Mon 29 Mar 10 @ 8:04 am
hi there you can buy the controls for the sound card on line this device makes your sound card working as a asio driver, i have the same problem for like 3 months i also instal windows as booth camp and now is working.
search in the net for the asio drivers for mac
is like 50 dlls
i use a macbook pro unibody
2.53
4 gb ram
250 hd
and works perfect
if you need any thing else let me know cause i pass for the same pain
reggards
is like 50 dlls
2.53
4 gb ram
250 hd
and works perfect
reggards
Posted Wed 31 Mar 10 @ 11:38 pm
