Forum: Old versions
Topic: Oh No!!! Just Upgraded to 3.0 and .... - Page: 1
80% of the tracks have lost their BPM info. Does this mean I have to rescan all files again?
Posted Sun 22 May 05 @ 8:15 pm
claxPRO InfinityMember since 2004
Very strange ... Do you have a backup of your database ?
What are your settings in the 3.0 ?
Posted Sun 22 May 05 @ 8:47 pm
xeonPRO InfinityModeratorMember since 2004
i didn't lost any info.
Dj Nikki
Posted Sun 22 May 05 @ 8:48 pm
Thanks Clax...Had to restore database.
Posted Sun 22 May 05 @ 9:51 pm
I lost all my BPMs as well. What is the fix?
ms
Posted Mon 23 May 05 @ 2:43 am
hmm
really strange
assuming that its written as VDJ idtag to file, when using 2.1, try this :
Turn ON read idtags in settings, see if that makes VDJ read back the bpm values
Posted Mon 23 May 05 @ 2:46 am
Just did it but nothing still.
MS
Posted Mon 23 May 05 @ 2:48 am
look in VDJ folder, see if there is made a backup of database when installing ?
Sort folder by date... to see if that happened today
Are there more than one database?
Posted Mon 23 May 05 @ 2:50 am
Which database? MP3? VDJ Database?
MS
Posted Mon 23 May 05 @ 2:53 am
VDJ database... the XML file
Posted Mon 23 May 05 @ 2:56 am
It has been updated with today's upgrade.
MS
Posted Mon 23 May 05 @ 2:57 am
Its updated each time you run vdj, so if you ran vdj today (as you did) its updated today...
BUT, do you have a copy of the database?
Anyway, reported it to Dev Team. Hopefully they can help you. I dont know why this has happened to you
Posted Mon 23 May 05 @ 3:00 am
Thanks for right now I am going to reinstall 2.1 and then make a copy of the Database.
Thanks.
MS
Posted Mon 23 May 05 @ 3:02 am
Just had to reinstall 2.1 and still have no BPMs.
MS
Posted Mon 23 May 05 @ 3:10 am
What I did to fix it was that I noticed that there were to database files. One was named " VirtualDJ Database.xml" and another "VirtualDJ Database(XXXXXXX).xml, the "xxxx" being a username. I had to delete the VirtualDJ Database.xml, created a copy of the VirtualDJ Databes(XXXXX).xml and rename to VirtualDJ Database.xml and problem was resolved.
Posted Mon 23 May 05 @ 3:11 am
djcelPRO InfinityModeratorMember since 2004
verify multi-users is disabled in the settings
Posted Mon 23 May 05 @ 3:12 am
Works like a charm! Someone upgrade this guy to Experienced Professional User!
Thanks buddy!
MS
Posted Mon 23 May 05 @ 3:14 am
Yeah Cel it was disabled. Manixx Thanks again.
MS
Posted Mon 23 May 05 @ 3:15 am
good ;) problem solved :)
Posted Mon 23 May 05 @ 3:34 am
Norway, Cel and Manixx thank you!
MS
Posted Mon 23 May 05 @ 3:49 am
54%
