Hey guys, I am looking to get into virtual DJing. I would say I was quite tech-savvy. I am seriously looking at the Hercules Steel
(http://www.decks.co.uk/products/Hercules/Steel)
Thing is to use it you need an external sound card right? Well what kind of soundcard do I need? Will something incredibly simple work?
(Like this http://www.decks.co.uk/products/behringer/UFO202)
Or will something more expensive be needed?
(Like this http://www.decks.co.uk/products/lexicon/Alpha)
What difference do these two actually have? I would be looking to play bedroom, small clubs and house parties sort of thing so I won't really need loads of audio outputs. Which sound cards would you recommend? Or would you recommend to just get something with a built in sound card? The Numark Omni-Control for example. Personally I like the look of the Hercules Steel much more than anything I've seen.
Oh yeah and price most definately IS a factor =P
Posted Wed 24 Mar 10 @ 5:59 pm
the hercules rmx has a built in soundcard.i used one for nearly 2 years and after set up ptoperly never had issues
Posted Wed 24 Mar 10 @ 6:49 pm
Hercules DJ Console RMX if you really want to go that way. Not top quality but ok..Get an NS7 or 2 pioneer cdj 400s and cases
worth it if your serious about Djing
DJ JAMM
DJ JAMM
Posted Wed 24 Mar 10 @ 7:28 pm
Like the guys sayd... The Hercules Rmx has a desent sound card....many people use this. theres a new card from Hercules youre supossed to "team up" with the "Steel" but total ( @ $600) would be twice as much,plus you'll be using up your USB outs that you will need for other things like camara,hard drives etc...the RMX is the best deal around...
Posted Wed 24 Mar 10 @ 8:11 pm
I have the STEEL console and i just use a cheap USB sound card about $20. I mean its just for the headphones. CHEAP!
But the thing is with that i'm only using the Master output on dest top speakers not Huge club speakers. Depends on what type of DJ you are. I just like DJ-ing at BBQs and Drinkouts....not at the clubs.
Posted Thu 01 Jul 10 @ 11:50 pm
