I have both songs and videos that will not load the waveform all the way. When this happens the gain on the song turns all the way down to -19. I play songs from the same album that were ripped from the same disc and they load completely. What could cause this?
Posted Mon 22 Mar 10 @ 11:16 am
check your max load setting?
Posted Mon 22 Mar 10 @ 12:37 pm
what should i set it to?
Posted Mon 22 Mar 10 @ 1:48 pm
that depends on the length of your largest file you use.
Posted Mon 22 Mar 10 @ 2:01 pm
Thank you. I set it to 15 mins seems to work fine now. the song is not 15 mins long tho.
Posted Mon 22 Mar 10 @ 2:23 pm
This also happens to me on a short song every once in awhile. After the song plays, it will say 4 minutes and you can replay. Load it in again, and the problem starts again. Anyone else see this before?
Posted Sun 22 Jun 14 @ 1:04 pm
This is probably because you have loaded a variable bit rate (VBR) file that has not yet been analysed by VirtualDJ. Please see our FAQ pages: https://virtualdj.com/wiki/MaxLoad.html
Posted Mon 23 Jun 14 @ 6:52 am
