Ok guys i want to release a podcast and i have one question, How can i record what i mix on my notebook/pc (Has nothing to do with Virtual Dj) ?
My dj set up ist:
+Pioneer djm 800
+2x Pioneer cdj 900
Thanks for the help. :)
My dj set up ist:
+Pioneer djm 800
+2x Pioneer cdj 900
Posted Mon 22 Mar 10 @ 9:31 am
''How can i record what i mix on my notebook/pc''
I meant on my mixing Dj pult and Recording it on my notebook... (without virtual dj)
Posted Mon 22 Mar 10 @ 9:33 am
yes you can as you write it...
You can use any LINE IN in your computer to record what you mix.
Anyway if you already have CDJ-900 and VirtualDJ Pro Trial, then you can use CDJ-900 as MIDI/HID controllers and VirtualDJ to record your MIX. It is the same way, just select in VirtualDJ REC FILE CONFIG you are going to record from LINE IN. that's it, you need to plu your REC OUT from your mixer to this LINE IN in your available line in input on the sound card you want to use for this (PC sound card in this case scenario)
Hope see you soon as a Full VirtualDJ Pro user and have full access to pro user benefits.
Posted Mon 22 Mar 10 @ 2:47 pm
Thanks Mate help alot got it all figured out, thanks to you.... Mixing right now, and yeah im getting virtual dj sometime next week the best software out there! and the RMX too.
Posted Mon 22 Mar 10 @ 4:55 pm
Your welcome ;-), VirtualDJ is a great software for sure.
Posted Mon 22 Mar 10 @ 5:22 pm
I have one question. Are there any features that are only available in The Pro version just want to know cause i basically tried everything on the trail version ? :)
Posted Fri 26 Mar 10 @ 2:05 pm
Maybe Netsearch, netsearch is the only thing that fully works on VirtualDJ Pro and you could have for 7 days only using VirtualDJ Trial version, but paying by SMS for it.
In this way you have Trial Version just the same as VirtualDJ Pro version. This is in the software operation, but when you are a customer of VirtualdJ Pro then you also have the benefits; like download all samples, effects, tools and skins in our website, also have access on the forum available only for pro users and also you could get free lifetime updates of VirtualDJ Pro.
Posted Sun 28 Mar 10 @ 2:45 pm
